Compoza_
Mar 09, 2021Luminary
Something is wrong with the Geo filter
https://imgur.com/a/CJeTmdg It seems like the Geo Filter is broken now, take a look at the picture. Any ideas? Regards
- Mar 10, 2021When that error appears, wait 1 minute and then refresh the page - it will have successfully flushed the cloud. What was the ping to that server?
Netduma-Fraser
Mar 09, 2021NetDuma Partner
It's likely the host is outside your zoom level, if you zoom out fully do you see the host? Did you enable filtering mode/change settings while you were already on the game?
Compoza_
Yes, I did see the host, it was in south africa. I live in Sweden och have set the geo filter point where I exactly live in Sweden, Europe," you can see it in the uploaded picture" and the host was on the other side of the planet. I did enable it before starting my PS4 console.
- Netduma-LiamMar 10, 2021NetDuma Partner
What game are you playing where you're seeing this? Are you seeing it across all games?
- Compoza_Mar 10, 2021Luminary
Actually it is only on Call Of Duty WW2. I was trying to use the Flush Cloud, but it actually haven't been working since I bought the router. I have the latest firmware for my router XR300.
- Netduma-FraserMar 10, 2021NetDuma PartnerWhen that error appears, wait 1 minute and then refresh the page - it will have successfully flushed the cloud. What was the ping to that server?
