Thawk21
Oct 11, 2018Aspirant
Source video issues
I moved to a new house fiber internet. 1gb up and down. My speeds seem fine but for some reason when watching twitch or YouTube, anything over 480p quality it starts to buffer. This happens from my pc...
Netduma-Fraser
Oct 11, 2018NetDuma Partner
What are your QoS settings?
Thawk21
I haven't changed anything. So whatever the defaults are out of the box.
- Netduma-FraserOct 11, 2018NetDuma PartnerHave you enabled the Geo-Filter? Are you using Smart Connect for wifi? If so disable and connect to 5GHz
- Thawk21Oct 11, 2018AspirantI do have smart connect turned off and am using 5ghz and I've tried hard wiring and still happens.
- Netduma_JackOct 13, 2018NetDuma Partner
The best step here is to isolate where the issue is. What happens if you connect these devices to your modem, does the issue continue?
If it does, then there's probably an overall problem with the line.
If they're fine, then there's likely to be an issue with the router.
Let us know what you find. Thanks.
