weez999
Jun 18, 2020Tutor
Speed issues with gigabit and xr500
XR500 with ARRIS NVG599 I have the XR500 with latest firmware with the Arris NVG599 on latest firmware. My internet both wired and wireless are laggy. Here is my setup: Background -Int...
Netduma-Fraser
Jun 18, 2020NetDuma Partner
I'm a bit confused about your setup, you didn't say exactly where your XR500 fits within the Modem/Switch setup.
Is it Modem > Switch
> Switch
> XR500
Or Modem > XR500 > Switch
> Switch
Also in QoS in the Anti-Bufferbloat menu disable QoS fully by selecting the option. Never just disables Anti-Bufferbloat and not the rest of the QoS features.
> Switch
> XR500
> Switch
- weez999Jun 18, 2020TutorOk I’ll remove QOS completely. I didn’t know that part.
As for your question:
Modem—>XR500–>switch- Netduma-FraserJun 21, 2020NetDuma PartnerThanks for clarifying, has disabling QoS helped at all? The S8000 I believe have their own version of QoS so I would actually recommend disabling these and enabling QoS on the XR instead so you're not using QoS twice.
- weez999Jun 21, 2020Tutor
I disabled it and there was no difference but I then read the DumaOS website for ideas of optimization and it now is at "when high priority traffic detected" and the percentages are both at 70%. I got to about 800 up and down so I'm still missing a little bandwidth but it seems the network pauses have stopped but I'll know come Monday when we are all online at the same time. (5 of us)
I did not think about my s8000 switches so I'll have to check on them to confirm QOS is on and how to completely disable it if it is on. I'll be in touch. Thank you for your tips so far, keep em coming even if you insist on keep QOS disabled on the XR and include some other optimization suggestions.
