weez999
Jun 18, 2020Tutor
Speed issues with gigabit and xr500
XR500 with ARRIS NVG599 I have the XR500 with latest firmware with the Arris NVG599 on latest firmware. My internet both wired and wireless are laggy. Here is my setup: Background -Int...
weez999
Jun 18, 2020Tutor
Ok I’ll remove QOS completely. I didn’t know that part.
As for your question:
Modem—>XR500–>switch
Netduma-Fraser
Jun 21, 2020NetDuma Partner
Thanks for clarifying, has disabling QoS helped at all? The S8000 I believe have their own version of QoS so I would actually recommend disabling these and enabling QoS on the XR instead so you're not using QoS twice.
- weez999Jun 21, 2020Tutor
I disabled it and there was no difference but I then read the DumaOS website for ideas of optimization and it now is at "when high priority traffic detected" and the percentages are both at 70%. I got to about 800 up and down so I'm still missing a little bandwidth but it seems the network pauses have stopped but I'll know come Monday when we are all online at the same time. (5 of us)
I did not think about my s8000 switches so I'll have to check on them to confirm QOS is on and how to completely disable it if it is on. I'll be in touch. Thank you for your tips so far, keep em coming even if you insist on keep QOS disabled on the XR and include some other optimization suggestions.
- DavJern73Jun 23, 2020Guide
I would call ATT and tell them to trade out your NVG599...I had the same problem with not getting my 1G with them...read in a ATT message board that the company started changing them out because they are a older model. Tell them you need the BDW210 modem/router ...that helped me get all my speeds back and I now have no problems.
- weez999Jun 23, 2020Tutor
DavJern73 wrote:I would call ATT and tell them to trade out your NVG599...I had the same problem with not getting my 1G with them...read in a ATT message board that the company started changing them out because they are a older model. Tell them you need the BDW210 modem/router ...that helped me get all my speeds back and I now have no problems.
Thanks, I'm gonna give them a ring tomorrow to see if they got one of them so long as it's bridgable...
