weez999
Jun 18, 2020Tutor
Speed issues with gigabit and xr500
XR500 with ARRIS NVG599 I have the XR500 with latest firmware with the Arris NVG599 on latest firmware. My internet both wired and wireless are laggy. Here is my setup: Background -Int...
weez999
Jun 21, 2020Tutor
I disabled it and there was no difference but I then read the DumaOS website for ideas of optimization and it now is at "when high priority traffic detected" and the percentages are both at 70%. I got to about 800 up and down so I'm still missing a little bandwidth but it seems the network pauses have stopped but I'll know come Monday when we are all online at the same time. (5 of us)
I did not think about my s8000 switches so I'll have to check on them to confirm QOS is on and how to completely disable it if it is on. I'll be in touch. Thank you for your tips so far, keep em coming even if you insist on keep QOS disabled on the XR and include some other optimization suggestions.
DavJern73
Jun 23, 2020Guide
I would call ATT and tell them to trade out your NVG599...I had the same problem with not getting my 1G with them...read in a ATT message board that the company started changing them out because they are a older model. Tell them you need the BDW210 modem/router ...that helped me get all my speeds back and I now have no problems.
- weez999Jun 23, 2020Tutor
DavJern73 wrote:I would call ATT and tell them to trade out your NVG599...I had the same problem with not getting my 1G with them...read in a ATT message board that the company started changing them out because they are a older model. Tell them you need the BDW210 modem/router ...that helped me get all my speeds back and I now have no problems.
Thanks, I'm gonna give them a ring tomorrow to see if they got one of them so long as it's bridgable...
- DavJern73Jun 24, 2020Guide
Yes that model is bridgeable...except on this model its called IP Passthrough...which is pretty much the samething...and you also have to to go into nat gaming make it find your xr 500
