Porkslapappy's avatar
Porkslapappy
Follower
Nov 18, 2019
Speeds drop wired connection xr500
No matter what I do I downgrade the firmware, update firmware again,factory reset everything, disable QOS, and the speed test to set up router shows correct speed 940/55 but within an hour it’s half t...
