hharamis
Apr 17, 2019Tutor
stack traceback error in logs
Hello,
I see the following ERROR in the logs freqently. Should I be concerened?
Running V2.3.2.40, with an incredible uptime of 65 days with no incidents. To be honest, i could never run th...
Apr 17, 2019Guru - Experienced User
Has a factory reset been performed since v40 was applied. Might try this if you just updated to v40 and continued to use the router with out a reset. Seen it were lingering code can still remain until a reset is performed.
- hharamisApr 17, 2019Tutor
I haven't done a factory reset in a while but can do that. Scared to touch it tho since its been so stable now.
I was mostly asking if the duma devs can make any sense or have seen such a nasty looking error?!?!
- Netduma-FraserApr 17, 2019NetDuma PartnerI would suggest you don't factory reset, you're not having issues so don't do anything. If it ain't broke don't fix it as they say. Errors can look nasty but they're quite common, as long as you're not experiencing any issues you can safely ignore it.
- FURRYe38Apr 17, 2019Guru - Experienced User
First do a back up of the routers config to file before doing a reset. Then see what happens after the reset with out loading the config. See if the logs still report these errors. If not, then re-load the saved config from file.
