hharamis
Apr 17, 2019Tutor
stack traceback error in logs
Hello,
I see the following ERROR in the logs freqently. Should I be concerened?
Running V2.3.2.40, with an incredible uptime of 65 days with no incidents. To be honest, i could never run th...
hharamis
Apr 17, 2019Tutor
I haven't done a factory reset in a while but can do that. Scared to touch it tho since its been so stable now.
I was mostly asking if the duma devs can make any sense or have seen such a nasty looking error?!?!
Netduma-Fraser
Apr 17, 2019NetDuma Partner
I would suggest you don't factory reset, you're not having issues so don't do anything. If it ain't broke don't fix it as they say. Errors can look nasty but they're quite common, as long as you're not experiencing any issues you can safely ignore it.
