usermac
Aug 10, 2018Luminary
STEAMLINK XR500 PERFORMANCE ISSUE
I am useing the steamlink to stream games and for some reason the performace seems worse on the XR500 compared to my old bt smart hub so I must have something set up not right. I am wondering if this...
Netduma_Jack
Aug 11, 2018NetDuma Partner
Hi there - you don't want to add it to Traffic Prioritisation. That's used for low latency, low bandwidth applications like gaming.
Instead, you want to use Bandwidth Allocation, which lets you set aside bandwidth for the devices you want to have it. I recommend you allocate as much bandwidth as you want to the device on Bandwidth Allocation. Do this for both upload and download.
I also recommend setting Anti-Bufferbloat to either 'Never' mode or 'High Priority Traffic Detected' mode and not setting the sliders any lower than 70%.
Now see if things are cleaner. If it's still choppy, go to the Network Monitor when it's being choppy and see if there are there any other devices on your network that are consuming a lot of bandwidth
- usermacAug 17, 2018Luminary
The way the Steam link works is it streems your gaming pc over the network onto the telly by LAN OR WIFI.
At the same time my pc is pluged into Nighhawk XR500 and also the Steam link. The steam link just needs the best connection either LAN or WIFI. No internet is needed as the gaming pc is the device that uses the internet and the steam link is kind of like a mirror as such working down the the network.
Does the XR500 and The ANTI- BUFFERBLOAT limit just internet speed or does it limit the speed of all networking tasks.
There was an option on the steam link that said enable trafic contol on modern routers I checked that and I belive it has inprooved things abit but I do get ocasional lag spike.
- Netduma_JackAug 17, 2018NetDuma PartnerAnti-Bufferbloat throttles your bandwidth to ensure congestion no longer occurs. So it does not limit anything other than your internet speeds. Other network tasks will not be impacted.
Have you allocated bandwidth using Bandwidth Allocation too?
Let me know if you have any other questions.- usermacAug 17, 2018Luminary
Thanks for getting back to me
I do not see any option for Bandwidth Allocation on the router but I do see an option on the steam link to priortize network traffic on the steam link is that what you mean ? Because I have that on please see picture
