DirtySZN
Jun 21, 2020Aspirant
Still lagging while gaming with ethernet connection
So I currently am having severe lag issues while gaming. I am hardwired meaning this -
There is a main xfinity gateway(modem/router combo) in one room in my house. That gateway is the main one and I have nothing to do with it. It is my mother's for her workstation and I do not bother with it.
In my bedroom I am hardwired - meaning I have a coaxial cable outlet in my room that I connect via coaxial cable to my Netgear CM1000 modem. From the modem, I am connected via ethernet cable to my Netgear nighthawk XR500 gaming router. And then there is one more ethernet cable from the XR500 to my gaming PC.
I have tried: connecting my PC only to my modem; that has failed as I still lag. I also have tried connecting as stated above, via modem & router to my PC; I lag. I have tried to connect WiFi to the Xfinity gateway across the house; I still lag... And when I mean lag, I am getting severe packet loss, my game freezes to the point I can't even play for over 5 seconds at a time, etc..
My equipment is all in perfect condition as far as the modem, router, and cables(brand new CAT-5E cable & CAT 6 cable; and it's a newer coaxial cable as well)
Me and my mother pay for Xfinity - speeds up to 600mbps download/15mbps upload. And we are getting just that. Even more; up to 700mbps download/20mbps upload.
And ping is great as well at 10-25 ping in game. The numbers are great, but I can't even play anymore due to all of this.
-Side note- I already contacted Xfinity about this in the past - they can't come out due to COVID currently, so I need an alternative for the time being if possible...
Any help would be appreciated! Thank you!
Do you pay for 2 different setups? Since you have a xfinity modem and a cm1000 listed?
I'm curious how its actually setup.
- DirtySZNAspirant
Well that is the thing. I don't pay for 2 different setups. Everyone is wondering how the one in my bedroom is even running. We don't pay extra at all. There is just the second coaxial cable port in my wall in my bedroom; so I plugged it up and it just runs connects.
- DirtySZNAspirant
My CM1000 is also listed as the second modem on the xfinity account because I called them once asking is it okay to have 2 different "setups" ran in the same household. The guy said that generally it us unusual, and sometimes it works, but in my situation it will not work.
I then got off the phone with him; set it up myself, and it just connected to the internet somehow.
2 modems actively running on 1 account could be your issue. Are they both showing as active on your account?
If you speedtest try hardwiring into them both and testing speeds on each individually and then test them both at the same time.
What speeds do you pay for?
What speeds do you get hardwired into both? seperate?
do you get the lag if you're directly connected to the modem?
