DirtySZN
Jun 21, 2020Aspirant
Still lagging while gaming with ethernet connection
So I currently am having severe lag issues while gaming. I am hardwired meaning this - There is a main xfinity gateway(modem/router combo) in one room in my house. That gateway is the main one and...
Jun 22, 2020Guru - Experienced User
DirtySZN wrote:I have tested that a few days ago when I was lagging all day long. And yes, I would lag the same amount. When connected to the modem and router, and then with the CM1000 as well.
So what could be going on here do you think?
Could it be my ISP, having 2 "setups" on one account, etc.? I am unsure to be honest, that's why I am posting here; thanks for the support so far.
If you're lagging without the router in the mix its either:
1. The game. you're connecting to servers that aren't optimal
2. The isp.
3. the modem. It could be having 2 on the account is causing issues. Or it could be a hardware issue. I'm doubting that if you get the issue on either modem.
Netduma-Fraser
Jun 23, 2020NetDuma Partner
Very weird setup, you mentioned sometimes it's good and sometimes it isn't - does that correspond to when your mother is using the other gateway by chance? E.g. if she isn't on the internet that day or is out does it play without lag?
