G4Captain
Aug 23, 2022Star
Strange Problem XR1000
I have a really unusual problem that started last week with my XR1000. The router seems to be randomly dropping the internet connection, while still maintaining the wifi signal. Any device connected ...
G4Captain
Aug 23, 2022Star
I have FIOS that's by Frontier now instead of Verizon. It's connected thru the old Actiontec router from Verizon that's in bridge mode. I've been running this way for a number of years without any issues. Nothing changed with the service.
I have to use the Actiontec still as it's a coax connection and all the guide/on screen programming for the tv is done by the Actiontec, at least that's what they tell me.
Aug 23, 2022Guru - Experienced User
It wouldn't be the first poorly implemented bridge mode that I've seen or an ISP that pushed an update to their device that fubar'd something.
Try putting the ISP device back in router mode (disable its wifi) and put the netgears IP address into its DMZ. that should automatically forward all the data to the netgear. see if that helps
- G4CaptainAug 23, 2022Star
I will give that a try and see what happens.
Thanks.- G4CaptainAug 25, 2022Star
So that didn't fix it.
The next thing I'm going to try is a factory reset when I get home in a few days, and then update again to the latest firmware. If that doesn't solve it, I guess the next step would be a new router as I would assume it's some kind of internal failure.
Anyone have any other thoughts or suggestions?
Thanks.- Netduma-FraserAug 25, 2022NetDuma PartnerIn LAN Settings, set the DHCP range to start at .50, then assign reserved IP addresses to devices between .2 & .49 so they're out of the DHCP range, apply, reboot from the interface, wait 2 minutes and see if that stops the disconnects.
