Misterswede's avatar
Feb 15, 2020
Streaming audio and stability
now that I have full speed and with or without QoS the issue is
speed test 300/200 mbit test directly to fiber nod
speed test via router the same and I thought all is well bu NOOOOOO
i go to shoutcast via lan and streaming audio hacks and stops at intervalls
this is at top floor and from router there is a cat6 cable in to a giga 8 port switch and there is the computer
streaming audi hacks, web pages stops loading like interference
I f I stream via WiFi all works
The router is factory reset but something is wrong
if I use web without xr700 all I super fast not hickups
I connect via router port to switch and 30m cat 6 and all as hickup
where the H shall I start in router settings
i have disabled QoS and all has 800/800 in speed settings
  • This took mew 2 hours of testing to find that the middle selection under QoS, antibuffer MUST be checked solved issue :-(
1 Reply
