Sleepy_one
Nov 26, 2018Aspirant
Sub domain of a webpage won't load properly
Howdy all,
I'm trying to access the webpage https://us.shop.battle.net/en-us . When it loads, I get a blue screen, and it won't load any further.
I originally used my ISP's DNS, but swap...
Sleepy_one
correction, my router is a CM1000.
- FURRYe38Nov 26, 2018Guru - Experienced User
Try a different browser?
That site works for me on Mac and Opera.
Please post this here for your model router:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
- Sleepy_oneNov 26, 2018Aspirant
Different browser does not work.
Factory reset the router and set up from scratch. Walk thru the setup wizard of the router and let it set up the connection.
Besure to clear any browser caches. Then try the site after this.
Try a different PC to see if same thing happens there.
Might set some custom DNS on the router as well, like cloudfare and quad9.
