Wyzfar
Oct 16, 2018Aspirant
Subnet mask
Hello ok so i have the nighthawk xr500 pro gaming router and i am wondering which subnet should i be using which one is the best because from my little understanding the subnet mask communicates with...
Netduma-Fraser
Oct 16, 2018NetDuma Partner
Theres no best to use subnet, it won't affect your online gaming performance. As long as its not the same as the upstream router/modem then you're fine.
- WyzfarOct 18, 2018Aspirant
idk what that means idk what subnet mask to use ....
- Netduma-FraserOct 19, 2018NetDuma PartnerJust use the default one which is 255.255.255.0, otherwise if you change it and you don't know what you're doing then you will encounter issues.
