Wyzfar
Oct 16, 2018Aspirant
Subnet mask
Hello ok so i have the nighthawk xr500 pro gaming router and i am wondering which subnet should i be using which one is the best because from my little understanding the subnet mask communicates with...
Wyzfar
Oct 18, 2018Aspirant
idk what that means idk what subnet mask to use ....
Netduma-Fraser
Oct 19, 2018NetDuma Partner
Just use the default one which is 255.255.255.0, otherwise if you change it and you don't know what you're doing then you will encounter issues.
