Toph_Bei_Fong
Aug 09, 2023Aspirant
support 2 gig?
https://www.netgear.com/home/wifi/routers/rax120/ I know the ports will only do 1 GB, which is fine, but will it do 2GB over wifi? Also I see port aggregation, does that mean I can combine the ...
Aug 09, 2023Guru - Experienced User
Depends if you have 4x4 mimo support on your wireless devices, then probably could.https://www.increasebroadbandspeed.co.uk/realistic-speeds-wi-fi-5-and-wi-fi-6
https://www.duckware.com/tech/wifi-in-the-us.html
Also I see port aggregation, does that mean I can combine the ports to get 2 gig speed out of them? If so, how many ports can I combine to make faster ports? LAG is only on the LAN side, not the WAN side. If you set the Multi gig for WAN support and got 2.5Gb here, possible you could enable LAG on the LAN side and see 2.5gb speeds with a ethernet connected device that supports LAG here.
also does it support access point mode? and if in access point mode, can I still use port aggregation?Yes and I think LAG is only in router mode.
Toph_Bei_Fong
Thanks!
- FURRYe38Aug 09, 2023Guru - Experienced User
đ
