Toph_Bei_Fong
Aug 09, 2023Aspirant
support 2 gig?
https://www.netgear.com/home/wifi/routers/rax120/ I know the ports will only do 1 GB, which is fine, but will it do 2GB over wifi? Also I see port aggregation, does that mean I can combine the ...
Toph_Bei_Fong
Thanks!
Aug 09, 2023Guru - Experienced User
