DOGGAVELI
Feb 22, 2019Star
SX10 Setup Help
Hi Everyone,
I recently got the Sx10 gaming switch my home setup is ISP modem to XR700 to Sx10 I have DMZ the switch in the Xr700.
When I game though I get lag/glitch...
Netduma-Fraser
Feb 23, 2019NetDuma Partner
The switch I believe has it's own QoS/traffic management. I would suggest you disable it as it may be interfering with the XR700 QoS.
- DOGGAVELIFeb 23, 2019Star
Hi Fraser,
I've actually been doing that but it still occurs so I have stopped using the switch at the moment and just using the XR700.
Brado has had the same issue as well, so I thought I'd post in here and see if anybody else had similar issues.
- Netduma-FraserFeb 23, 2019NetDuma PartnerOkay so it's all fine with the XR700?
Yes sure is mate, just dissapointed with the switch just doesn't seem to be functioning to the levels I expected so stopped using it until somebody can assist a little further with settings.
