DOGGAVELI
Feb 22, 2019Star
SX10 Setup Help
Hi Everyone,
I recently got the Sx10 gaming switch my home setup is ISP modem to XR700 to Sx10 I have DMZ the switch in the Xr700.
When I game though I get lag/glitch...
Brado78
Feb 27, 2019Star
Hi Fraser,
Yes have as Rob stated have all ready tried this has not helped the issue.
I have over the last couple of days have been using bandwith rate limiting, has helped a little by making issue not last as long.
Regards John
Netduma-Fraser
Feb 28, 2019NetDuma Partner
That's a shame John, I'd suggest making contact with Christian as well then and he should be able to help.
- Brado78Mar 22, 2019Star
Netduma-Fraser wrote:
That's a shame John, I'd suggest making contact with Christian as well then and he should be able to help.Hi Fraser and Christian,
Sorry i did not have the chance to conatct Christian. Also decided to just use the XR700 as netgear support made contact with Rob and could not help solve the issue.
So wonder if the issue could be a issue with firmware version 1.0.1.8 on the XR700 ?
Udated to XR700 Firmware Version 1.0.1.10 thought i would try to switch again. To my supprise all issues i was expereince are gone and connection feels sweet as. That is also using qos on the xr700 and switch. :)
I did roll back to firmware version 1.0.1.8 this morning as could not stand the slow loading times of the GUI. Thought would test out switch again on that firmware as in the time i have not been using switch have also had two upgrades at my local exchange. Thought it might have been the upgrades at my exchange stopping the issue.
However once i rolled back to firmware version 1.0.1.8 same issues occured once again. So have now upgraded to version 1.0.0.10 and once again the XR700 and switch combo are working sweet as.
So think i will put up with the slow GUI for now as enjoying the sweet connection of the XR700 and switch combo.
Regards John
- Netduma-FraserMar 23, 2019NetDuma PartnerI'm not sure if it's firmware specific given that either way using two QoS solutions at the same time is not a good idea. So very strange it worked better on the new firmware! Were any settings changed between firmware?
For the new firmware I'd suggest doing a factory reset then clearing the browser cache/cookies to see if the interface speeds up. We have let the teams know though as some others are experiencing slower UI - Brado78Mar 24, 2019Star
For the new firmware I'd suggest doing a factory reset then clearing the browser cache/cookies to see if the interface speeds up. We have let the teams know though as some others are experiencing slower UIHave not changed any setting in switch just default settings. No settings changed between firmwares on the XR700.
Will stick with 10.0.10 XR700 firware for now. As very rarley i change any settings so can live with the slow UI for now.
These are the reasons why i end up buying the switch and 10gb sfp+ and to be honest has done what it states. Expect the issues i was having with switch using the previous XR700 firmware
Regards John
- Netduma-FraserMar 24, 2019NetDuma PartnerThanks for the information John, we'll keep an eye on this. Glad to hear you're getting a great connection!
- Brado78May 09, 2019StarHi Fraser though I would give an update. So tried all different firmware using SX10 switch no issues at all unless using .8 firmware on XR700.
Rob and I are now both enjoying our XR700 and SX10 switch 10gb set up. Truly amazing what both of them do working together with no lag issues. 🙂👍 - Netduma-FraserMay 09, 2019NetDuma PartnerThanks for the update and fantastic to hear that!
