DOGGAVELI
Feb 22, 2019Star
SX10 Setup Help
Hi Everyone,
I recently got the Sx10 gaming switch my home setup is ISP modem to XR700 to Sx10 I have DMZ the switch in the Xr700.
When I game though I get lag/glitch...
Brado78
Mar 24, 2019Star
Netduma-Fraser wrote:
I'm not sure if it's firmware specific given that either way using two QoS solutions at the same time is not a good idea. So very strange it worked better on the new firmware! Were any settings changed between firmware?
For the new firmware I'd suggest doing a factory reset then clearing the browser cache/cookies to see if the interface speeds up. We have let the teams know though as some others are experiencing slower UI
Have not changed any setting in switch just default settings. No settings changed between firmwares on the XR700.
Will stick with 10.0.10 XR700 firware for now. As very rarley i change any settings so can live with the slow UI for now.
These are the reasons why i end up buying the switch and 10gb sfp+ and to be honest has done what it states. Expect the issues i was having with switch using the previous XR700 firmware
Regards John
Netduma-Fraser
Mar 24, 2019NetDuma Partner
Thanks for the information John, we'll keep an eye on this. Glad to hear you're getting a great connection!
- Brado78May 09, 2019StarHi Fraser though I would give an update. So tried all different firmware using SX10 switch no issues at all unless using .8 firmware on XR700.
Rob and I are now both enjoying our XR700 and SX10 switch 10gb set up. Truly amazing what both of them do working together with no lag issues. 🙂👍 - Netduma-FraserMay 09, 2019NetDuma PartnerThanks for the update and fantastic to hear that!
