ndg317
Oct 28, 2019Aspirant
Teredo ip address/NAT type unavailable xr500
When I use strictly wifi, my Xbox One X, after awhile of game play, keeps telling me that my NAT type is unavailable and then the teredo ip address pops up. What I've read from xbox support is that my...
Netduma_Alex
Oct 29, 2019NetDuma Partner
Under Settings > Advanced Settings > IPv6 on your router, what is IPv6 set to? I think this might be an issue with IPv6.
ndg317
Oct 29, 2019Aspirant
Also, teredo ip address or NAT type unavailable has haunted me every since I bought my xr500. During my initial setup, in geo-filter, I added my Xbox One X, but after gaming for awhile teredo ip address popped up. I realized that, in geo-filter, I had to click "spectating mode" opposed to the default "filtering mode" for concoles.
- Netduma-FraserOct 29, 2019NetDuma PartnerThat means the Geo-Filter was blocking the server that checks the NAT status but that shouldn't actually affect your connection at all. When you get the message does it stop you playing or prevent you connecting to people etc or is it just a message?
- ndg317Oct 29, 2019AspirantIt’s actually all of the above. I know when I get the teredo message because I get kicked out of my party. I then test my NAT type and it says unavailable and refers to teredo ip address. Or my party and game starts lagging then I get kick out the party and game. Match making is non existent and my NAT type becomes strict
- Netduma-FraserOct 29, 2019NetDuma PartnerOkay that is interesting. Could you give the console a static/reserved IP in Settings > LAN Setup and then put that same IP in the DMZ in WAN Setup and see if that resolves it please.
