ndg317
Oct 29, 2019Aspirant
Teredo ip address/NAT type unavailable xr500
When I use strictly wifi, my Xbox One X, after awhile of game play, keeps telling me that my NAT type is unavailable and then the teredo ip address pops up. What I've read from xbox support is that my...
ndg317
It’s actually all of the above. I know when I get the teredo message because I get kicked out of my party. I then test my NAT type and it says unavailable and refers to teredo ip address. Or my party and game starts lagging then I get kick out the party and game. Match making is non existent and my NAT type becomes strict
Netduma-Fraser
Oct 29, 2019NetDuma Partner
Okay that is interesting. Could you give the console a static/reserved IP in Settings > LAN Setup and then put that same IP in the DMZ in WAN Setup and see if that resolves it please.
- ndg317Oct 29, 2019AspirantYes, I will try. I apologize in advance if it takes me awhile to message back, I’m currently at work, but I’ll try as soon as I get home. Do you think it has anything to do with my IP address and my WAN not matching up?
- Netduma-FraserOct 29, 2019NetDuma PartnerUnlikely. The router would only show the public WAN IP address as it's own IP address if you're connected directly to a modem. If you're connected to a router then the router would be giving the XR500 a WAN IP. Let us know how you get on.
- ndg317Oct 29, 2019AspirantI have a Netgear - 32 x 8 DOCSIS 3.1 cable modem that connects to my xr500 via cat6 Ethernet cable and another cat6 Ethernet cable running to my Xbox One X
