eedjut
Jul 11, 2020Aspirant
Teredo unable to qualify
Hi, I'm having trouble playing cross play/inviting friends to streets of rage 4. I've had no issues with any other xbox/pc crossplay game until now and when checking my xbox networking it comes up wi...
Netduma-Fraser
Jul 11, 2020NetDuma Partner
I would suggest you start by disabling the Geo-Filter given you're playing locally and we haven't specifically tested the game for multiplayer. If that doesn't help then I would recommend in WAN Settings changing NAT to Open.
eedjut
Thanks for the reply and suggestions. How do i disable the geo filter? I can only de-select strict mode, auto ping host and flush cloud.
- Netduma-FraserJul 11, 2020NetDuma PartnerFrom the devices panel at the top of the Geo-Filter you can delete the device, alternatively you could switch it to Spectating mode which will prevent it filtering connections.
