Sambmx450
Dec 23, 2020Aspirant
Terrible speeds with XR500 and AC1900
So i have a Router and Modem that I upgraded from my ISP standard. Currently we are paying for 150mbps Download and 10Mbps Upload on Suddenlink. The Modem I have is the CM1000, The router is XR500. I...
Netduma-Fraser
Dec 28, 2020NetDuma Partner
If you're getting less speeds with two completely different routers then its either the modem or the ISP. Even when you're plugging directly into the modem you're not getting your full speeds either. Do you have another modem you could try?
