Lashn
Sep 23, 2018Aspirant
The connection to this site is not private
Me and my brother recently got an XR500 gaming router and when i go to log into the DumaOS site it says the following on the log in screen (your connection to this site is not private) instantly my h...
Netduma_Jack
Sep 23, 2018NetDuma Partner
Hi Lashn - what url are you putting in exactly? You should put in http://routerlogin.net
If you put an ‘s’ In front of http (so it reads https) then the browser thinks it’s getting an https connection which the admin panel doesn’t have (it doesn’t really need it because it’s on your local network)
Also you can ignore all those Dos attack warnings. It’s just internet noise. If you Google it you’ll see many threads on these forums explaining that it’s nothibg to be concerned about.
Lashn
My url is currently www.routerlogin.net with no https anywhere and when i enter http at the beginning of the url it says for me to relog with my admin and password i enter it and it just keeps popping back up with login details
- Netduma-FraserSep 23, 2018NetDuma PartnerDouble check you're putting in the correct details. If you are then click cancel and should prompt you to recover user/password by inputting your recovery question answers.
- LashnSep 23, 2018Aspirant
I most certainly am putting in the right details for the https site bit yet it still says im getting it wrong!
Is the username and password the same on www.routerlogin as to https://routerlogin? If not i have absolotely no idea on what to do i even done my security questions and it says i have them wrong when i 1000% know these questions of by heart
I can use the www. webstie but just not the https thats so odd
Now i cant seem to log in to DumaOS it comes up with missing JSON response
