Lashn
Sep 23, 2018Aspirant
The connection to this site is not private
Me and my brother recently got an XR500 gaming router and when i go to log into the DumaOS site it says the following on the log in screen (your connection to this site is not private) instantly my h...
Lashn
Sep 24, 2018Aspirant
I cant seem to log in to my routerlogin now and the router is spiking very high aswell as disconnecting please i need help
schumaku
Sep 24, 2018Guru - Experienced User
Lashn wrote:
I can use the www. webstie but just not the https thats so odd
No, the Netgear designed "capturing" of routerlogin.com and routerlogin.net (and alternate domains for other product types like Wireless Extenders or Orbi) can't work the same way if https is used on the same (W)LAN. That's why they stick to http on all these devices (regardless of DumaOS or Netgear's OS/DK) and the users get the subject warning on modern browsers.
Spiking noise? Hardware issue on the voltage regulation. Time to file for an RMA.
- LashnSep 24, 2018Aspirant
I have no idea what you just said!
Is there any possible way i can make it http?
- Netduma-FraserSep 24, 2018NetDuma PartnerLogin would be the same for http and https. I would strongly recommend just using http. Inputting routerlogin.net in your browser should default to http anyway.
I would recommend doing a factory reset on the router and set up from scratch, setting a new admin/password.- schumakuSep 24, 2018Guru - Experienced User
Netduma-Fraser wrote:
Login would be the same for http and https.However https is only available with remote management enabled, and only on the Internet/WAN port/address.
I would strongly recommend just using http. Inputting routerlogin.net in your browser should default to http anyway.Leaving the routerlogin.net handling away - there is no other choice as there is no https daemon listening on the (W)LAN side anyway, isn't it?
