Lashn
Sep 23, 2018Aspirant
The connection to this site is not private
Me and my brother recently got an XR500 gaming router and when i go to log into the DumaOS site it says the following on the log in screen (your connection to this site is not private) instantly my h...
Netduma-Fraser
Sep 24, 2018NetDuma Partner
Login would be the same for http and https. I would strongly recommend just using http. Inputting routerlogin.net in your browser should default to http anyway.
I would recommend doing a factory reset on the router and set up from scratch, setting a new admin/password.
schumaku
Sep 24, 2018Guru - Experienced User
However https is only available with remote management enabled, and only on the Internet/WAN port/address.
Leaving the routerlogin.net handling away - there is no other choice as there is no https daemon listening on the (W)LAN side anyway, isn't it?
- Netduma-FraserSep 24, 2018NetDuma PartnerYou can access the interface via https://routerlogin.net from the LAN side schumaku. Though I wouldn't recommend it.
- schumakuSep 24, 2018Guru - Experienced User
You can access the interface via https://routerlogin.net from the LAN side schumaku. Though I wouldn't recommend it.Can you please elaborate a little bit more? Is this some hit-and-miss on DumaOS like on the "other" router platform? In fact it's brilliant and it would not cause people complaining about the "Not secure" or "The connection to this site is not private" warnings from the browsers.
Needless to say, form the security audit prospective an almost public shared private key - as it's in place on all Netgear routers, or at least on these of a similar firmware release generation - does not add much privacy. But it would make the browsers and most customers happy.- Netduma-FraserSep 24, 2018NetDuma PartnerI believe Netgear are looking at a security certificate to ensure accessing via HTTPS is secure, I don't have a date or any more information on this but I know it's something they want to do. I imagine more for when the interface is accessed remotely rather than locally but would apply for both.
