Lashn
Sep 23, 2018Aspirant
The connection to this site is not private
Me and my brother recently got an XR500 gaming router and when i go to log into the DumaOS site it says the following on the log in screen (your connection to this site is not private) instantly my h...
richc9990
Dec 22, 2018Guide
hi just installed a new orbi mesh router plus 2 satelites. all working fine. but using chrome browser on windows10 i'm getting the connection is not private message on most (but not all) sites. including 192.168.1.254 from a laptop. no problems on a mobile device.
i've checked the date and the privacy settings.
any thoughts and help please?
- schumakuDec 22, 2018Guru - Experienced User
Not sure right now if Orbi does support https - try https://orbilogin.net/ while connected to your Orbi (W)LAN - and you know. I know that this URL is included in the Netgear installed certificates. Well, you might be happy then because the browser does no longer complain about an insecure connection. I'm not really - as all these certificates are using the same private keys, distributed with each Netgear device.
Any site with just a plain IP address or even a https site with a self-signed or expired or the like certificate will be marked as insecure - complete unrelated to the new Orbi system.And no, the Orbi won't interfere with other Web sites, neither on your (W)LAN, no on your Internet connection - if your browser says it's not secure, the same problems as lined out above apply. But that's not an Orbi problem.
