Kierok3
Apr 06, 2019Guide
Thinking of returning XR500
I have two ps4s wired connection to my new XR 500 router. I'm trying to match the two systems into the same crucible game in destiny 2 but the geo filter doesn't seem to have any effect on this. I'm l...
Netduma-Fraser
Apr 07, 2019NetDuma Partner
Hello, I'll answer in this topic as your other one is about the same thing, no need to make multiple topics.
If I'm correct you want to just find each other in the same game instead of going in as a team from the lobby? If so then I don't think this would be possible or it would be very hard to do so. To team up both devices should be added to the Geo-Filter just in case and then use the Destiny profile to set up this filter.
Kierok3
Apr 07, 2019Guide
Hi there!
Thanks for the response. It is possible, I have been in lobbies with other people doing it. I think it has something to do with white listing everyone from both fireteams but I'm not sure what I need to choose for my geo filtering home location. I was hoping to find someone that knew this on the forums.
- Netduma-FraserApr 07, 2019NetDuma PartnerThe only way that I could possibly think would be to place your location in the ocean at the same point with strict mode enabled and ping assist at 0. If you're only doing it with two people then I doubt that this would work.
- Kierok3Apr 07, 2019GuideWhat do you mean at the same point? 2 consoles are on one router, I only get to select one point. I added both consoles to the geo filter option on my computer and selected one spot in the ocean. What does strict mode do? I heard it was not supposed to be used for destiny but what if everyone was white listed?
- Netduma-FraserApr 07, 2019NetDuma PartnerIf you were to try and get into games with specific other people then the only way I could think of would be to have everyone have their Geo-Filter in the same place. Strict Mode keeps anything from outside your radius being allowed. No we recommend it being off for Destiny but thats the only thing I can think of. Potentially, are you trying to get in a game with the person in your house or other people also?
