Kierok3
Apr 06, 2019Guide
Thinking of returning XR500
I have two ps4s wired connection to my new XR 500 router. I'm trying to match the two systems into the same crucible game in destiny 2 but the geo filter doesn't seem to have any effect on this. I'm l...
Netduma-Fraser
Apr 10, 2019NetDuma Partner
Well in terms of QoS all devices should be connected to the router in order for you to receive the benefit. It terms of being easier to match up if you had them both on the router you could add both devices to be filtered and then should make it simpler for them to join together. If you're trying to force then ping assist might get you people that aren't who you want.
Kierok3
Apr 10, 2019Guide
Thanks Fraser, that is good to know. I will let you know how it goes when I try it next. I appreciate all the help!
