PenguinGatez
Jun 19, 2020Follower
This R-App is not loaded yet, please try again in a minute.
Can anyone help me? I have the XR700 GAMING ROUTER and i kept getting this message This R-App is not loaded yet, please try again in a minute. Anytime i try using any of the apps, does anyone know a ...
Jun 20, 2020Guru - Experienced User
What firmware are you on?
Have you looked at these at all?
Netduma-Fraser
Jun 21, 2020NetDuma Partner
Upgrade to this firmware and then perform a factory reset and that should resolve your issue: https://kb.netgear.com/000061714/XR700-Firmware-Version-1-0-1-24-Hot-Fix
