vanderboegh's avatar
Apr 09, 2018
Time Schedule
I want to turn off the gaming computers and systems in our house every weekday at midnight and have them turn back on at 7am. Is there a setting in the XR500 that will allow me to accomplish this?
Thanks!
  • No there isn't. The turning on could be possible if Wake On Lan was implemented on all your devices but I don't know if it'd be possible to send a shutdown command. Either way I'll add it to the ideas list for the Developers!
    • vanderboegh's avatar
      vanderboegh
      Tutor
      So how would I manually shut of the wan via the interface at midnight?
      Thanks
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        If you go to Content Filtering you may be able to block the internet at certain times/days
