S219
Mar 24, 2018Guide
Timestamp is wrong on system information logs
I've currently got a possible trojan on one of my machines. My logs keep showing 15 invalid login attempts after I login successfully. I was trying to see what processes would run while I logged in and also check the log and see if the program was still trying to login but the time shows 2 hours earlier. How do you change the time or update it?
- There is and it’s in a weird place. I think it might either be in >Settings >Content Filtering or it’s in Settings then Email.
- Netduma_JackNetDuma PartnerThere is and it’s in a weird place. I think it might either be in >Settings >Content Filtering or it’s in Settings then Email.
- S219Guide
Thank you! Your answer was close enough. I found it in settings>content filtering>schedule and saw that my time zone was wrong.
- Netduma_JackNetDuma PartnerNice one! Thanks for letting me know.
