Rdanderson7
Jan 31, 2023Initiate
Too Many Unnamed devices on my XR500
Good Day Netgear Community,
I purchased a Netgear XR500 about 2 years ago. Absolutely love the hardware but, I have a big issue with all the unknown devices that continually show under the Device Manager. Anyone have a resolution for this nagging issue?
Do you use apple products?
Their private mac/ip address feature can do that. - Netduma-FraserNetDuma PartnerGood advice above, also if you give static/reserved IPs to devices that should reduce it as well.
Do you do that in Settings > Setup > LAN Setup > Address Reservation > Add?
- Netduma-LiamNetDuma Partner
That's correct, yes.
