McFlyDK
Mar 29, 2019Aspirant
Torrent Downloader?
Hi guys.
I've just purchased a XR700, and have connected an USB HDD to the USB 3.0 plug. I want to run a torrent downloading tool on the router, for downloading to the USB (like Transmission on...
schumaku
Mar 29, 2019Guru - Experienced User
McFlyDK wrote:
I want to run a torrent downloading tool on the router, for downloading to the USB (like Transmission on other Netgear routers and Downloadmaster on ASUS routers). Where do I find this option in the XR700 (DumaOS)?
No such feature on the Netgear Pro Gaming routers I'm afraid.
McFlyDK wrote:
Also: How do I customize the content on the Dashboard? (I accidently removed the WiFi window, and can find anywhere to restore it).
Start with the "Pin" icon .... FMI DumaOS Optimal Settings Guide: Dashboard, Network Monitor and Device Manager
McFlyDK
Thanks very much for the quick reply!
Do you know of any "workaround" to use the router to download torrents to USB?
- Netduma_JackApr 02, 2019NetDuma Partner
I don't think it's possible unfortunately
- schumakuApr 02, 2019Guru - Experienced User
No way to add-in or pack some popular BT builds (especially the "lighter" ones) as a DumaOS R-Apps Netduma_Jack ? That woud be a real break-through ...
That's a cool idea! Added it to our roadmap / list of ideas. Thanks for the suggestion
