McFlyDK
Mar 29, 2019Aspirant
Torrent Downloader?
Hi guys.
I've just purchased a XR700, and have connected an USB HDD to the USB 3.0 plug. I want to run a torrent downloading tool on the router, for downloading to the USB (like Transmission on...
McFlyDK
Thanks very much for the quick reply!
Do you know of any "workaround" to use the router to download torrents to USB?
Netduma_Jack
Apr 02, 2019NetDuma Partner
I don't think it's possible unfortunately
- schumakuApr 02, 2019Guru - Experienced User
No way to add-in or pack some popular BT builds (especially the "lighter" ones) as a DumaOS R-Apps Netduma_Jack ? That woud be a real break-through ...
- Netduma_JackApr 02, 2019NetDuma Partner
That's a cool idea! Added it to our roadmap / list of ideas. Thanks for the suggestion
Transmission or rtorrent should not be difficult ...Usually I get some NFR samples or beer 8-)
Think about a wrapper for including popular repos like Entware https://pkg.entware.net/binaries/armv7/Packages.html ...
