sirzepp
Dec 06, 2019Follower
Traffic Meter on XR500 Only Allows 6 Digits
Hey All, I just signed up with Cablelynx here in Texas and they have a 2 TB datacap. We also have Disney+ and it can stream at 4K. I'd rather not implement device-level data limits because we stre...
Dec 06, 2019Guru - Experienced User
I would contact NG support about this, something they may have not considered.
You can try this yourself. Just login with eg telnet and issue this one-liner command:
Code:
sed -i "s#^exit 0#sed -i 's/\>999999\)/\>999999999\)/g' /www/traffic.js \&\nexit 0#" /etc/rc.local
If this doesnt' work, you'll need to ask NG to look into this.
Netduma-Fraser
Dec 06, 2019NetDuma Partner
Would echo what has been said above, that's a Netgear feature so they will have a better idea of what to do about that.
