Alewi
Nov 10, 2019Apprentice
Traffic prioritization help!
Hi nighthawkers, I want to add my ps4 manually to traffic prioritization. The steps are add device, chose a game! Here is the issue... the game I want is pro evolution soccer 2020, which is not liste...
Alewi
Nov 11, 2019Apprentice
Hi Alex,
I will try it and tell you what gonna happen. Another quistion. Is there any way where I can get the ps4 directly prioritized when I turn it on and before i start a game?
Netduma_Alex
Nov 12, 2019NetDuma Partner
I personally would recommend just using the DumaOS Classified Games option
- AlewiNov 12, 2019ApprenticeI think it is the only way possible. I tried to adjust the input manually and I left the source port as default (1-65535) and I tried many ports for destination port, for example (80). When I do that, the traffic prioritization is triggered as soon as I run the ps4 but I can't use the anti bufferbloat, so I can't control the bandwidth. When I put the source port as (80) and the destination port as (80) the traffic prioritization is not triggered! I tried to cahange the ports and still not triggered. I think it is a software's bug or something. So I will stuck with default Duma sittings. Thank you for your answer.
- Netduma-FraserNov 12, 2019NetDuma PartnerIt's not a bug. Either using DumaOS Classified Games or use the 'Console' service to add the PS4 manually and it will work and allow you to use QoS at the same time.
- AlewiNov 12, 2019ApprenticeHi Fraser,
You are not answering my question. I know the default works fine and I know if I use to add the ps manually and choose games console also works fine, but both options will triggered just when I run a game or do a connection test on ps4. My question was if there is anyway I can make my ps4 get top priority when I turn it on and keep that always without starting a game. If there is not, then thank you.
