jeremyg237's avatar
jeremyg237
Luminary
May 17, 2018
Traffic Prioritization multiple xbox's
I have 2 xbox's in my house. What do you recommend the settings do be so that when my son is playing his it does not take priority?(which it should not) Im thinking add device-my xbox-advanced rule...
  • Netduma-Fraser's avatar
    May 17, 2018
    Gaming barely uses bandwidth so there would be absolutely no issues prioritizing them both. However to do what you want disable DumaOS Classified Games and simply add your Xbox with the Games Console service.
