Lumihaze's avatar
Lumihaze
Traffic prioritization PC COD
Some of the servers that I connect to don't have prioritization. Can I add them manually? Duma os 3.0 beta btw.
  • It doesn't work on a per server basis, it should be for the device/game as a whole. How have you added the device to Traffic Prio exactly?
    • Lumihaze's avatar
      Lumihaze
      geo-filter -> add device -> desktop -> call of duty (PC). when i load into a game and start playing and check if high priority traffic is detected the red indicator doesnt show up but it does for fortnite.
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Instead of the CoD service, use the Games Console service instead and then it will prioritize correctly for both games.
