Laryke
Oct 14, 2021Apprentice
traffic prioritization warzone
I found the ports for warzone but I'm little confused at how to insert them, should I let source port default (1-65335) or should I change to 3074 (for example, one of the ports) and the destination ...
Netduma-Fraser
Oct 14, 2021NetDuma Partner
You keep the source port default and change the destination port. Classified Games/Games Console will prioritize it anyway but some people like to choose ports instead. I would recommend you have one or the other enabled, not both.
Laryke
Also, should I use normal or gaming/voice, and apply to wan server or not?
