Laryke
Oct 14, 2021Apprentice
traffic prioritization warzone
I found the ports for warzone but I'm little confused at how to insert them, should I let source port default (1-65335) or should I change to 3074 (for example, one of the ports) and the destination ...
Laryke
Also, should I use normal or gaming/voice, and apply to wan server or not?
Netduma-Fraser
Oct 14, 2021NetDuma Partner
Normal is if you're playing over ethernet, Gaming/voice is if you're using WiFi. Apply to WAN is optional, if your ISP supports priority tags then you may have slightly increased performance with it enabled.
