Wyzfar
Feb 16, 2019Aspirant
traffic prioritization
im prioritizing CoD: Bo4 for PS4 in the advanced tab using port 3074 udp is the source port and destination port 3074 for start and end ?
Netduma_Jack
Feb 19, 2019NetDuma Partner
You can use the same number for both
- WyzfarFeb 19, 2019AspirantOk so I don’t have to use the source range 1:65535 ? And would there be any benefit to prioritizing the ps4 ports as well
- Netduma-FraserFeb 19, 2019NetDuma PartnerDumaOS Classified Games prioritizes the console automatically so there should be no need to manually add ports for any game on a console. No you don't have to, it defaults to that range to prevent people making misconfigurations. Yes there would be benefit as long as you don't prioritize downloads.
ok and this is a odd question but what if i prioritize ports 1-65535 TCP/UDP will it automatically prioritize the ports that are open on that ip aka my ps4 ?
