Compoza_
Mar 21, 2021Luminary
Traffic Prioritization
High Priority Traffic Detected is still active despite I have my ps4 pro totally shut down. This causes alot of problem when I have Anti-Bufferbloat set to "When High Priority Traffic Detected". This...
Netduma-Fraser
Mar 21, 2021NetDuma Partner
We are aware of some issues with TP on the 300, are you using Classified Games or did you make a manual rule? We are working on it but I don't have an ETA at present
- Compoza_Mar 22, 2021LuminaryI'm using Classified Games.
- Compoza_Mar 22, 2021Luminarycould I use third party firmwares for my router?
- Netduma-LiamMar 22, 2021NetDuma Partner
Could you please try manually making a rule for your Playstation and see if the issue persists?
I'm afraid not, you'll only be able to use DumaOS firmwares.
Yes, the high traffic prioritaztion detected is still red/active. But the numbers of the total packet doesn't change. Is the issue only a visual glitch?
