Compoza_
Mar 21, 2021Luminary
Traffic Prioritization
High Priority Traffic Detected is still active despite I have my ps4 pro totally shut down. This causes alot of problem when I have Anti-Bufferbloat set to "When High Priority Traffic Detected". This...
Compoza_
Mar 22, 2021Luminary
could I use third party firmwares for my router?
Netduma-Liam
Mar 22, 2021NetDuma Partner
Could you please try manually making a rule for your Playstation and see if the issue persists?
I'm afraid not, you'll only be able to use DumaOS firmwares.
- Compoza_Mar 22, 2021Luminary
Yes, the high traffic prioritaztion detected is still red/active. But the numbers of the total packet doesn't change. Is the issue only a visual glitch?
No, it's not a visual glitch, when I set the "When High Priority Traffic Detected", and doing a speedtest by SPEEDTEST by Oakla, I don't get the full speed. But when I set it to "Never" I get the full speed.
I just realized that it is active for all devices I'm using, not only for my playstation 4 console. So it proritizing for all devices... That's why it causes the problem...
- Netduma-LiamMar 22, 2021NetDuma Partner
That makes sense! Go ahead and make a rule specifically for the PlayStation and let us know if the issue persists!
