vfathom's avatar
vfathom
Initiate
May 13, 2022
Trouble port forwarding on XR700 Gaming router
My current setup consists of a modem/router in one connected to my netgear router. The all-in-one creates its own wifi network and the netgear does as well. I've been trying to port forward a minecra...
  • Netduma-Fraser's avatar
    May 14, 2022
    Copy the WAN IP from the XR System Information page and put that in the modem DMZ, disable any port forwarding rules you've made on the modem then do it on the XR and it should work.
