Lucky_K_Ducky
Jan 28, 2021Follower
Trouble w/ all Apple Products
Hello! We just moved to a new home where we switched to Suddenlink and brought a brand new router - the XR500 Nighthawk Pro Gaming Router. I am able to use the wifi no problem with my Windows laptop,...
Netduma-Liam
Feb 04, 2021NetDuma Partner
Thanks for posting!
What firmware are you currently running? I'd advise making sure you're up to date, you can find the latest firmware here:
https://www.netgear.com/support/product/XR500#Firmware%20Version%202.3.2.66
If you do need to update, make sure you perform a factory reset after the update!
