Lucky_K_Ducky
Jan 28, 2021Follower
Trouble w/ all Apple Products
Hello! We just moved to a new home where we switched to Suddenlink and brought a brand new router - the XR500 Nighthawk Pro Gaming Router. I am able to use the wifi no problem with my Windows laptop,...
Netduma-Fraser
Feb 04, 2021NetDuma Partner
What WiFi settings are you using currently? Are you using Smart Connect? If so disable that and see if they can connect more easily.
