Mrbchambers
Feb 18, 2020Guide
Troubling messages in log: Dos Attack: DHCP leases changinging: Geofilter Changing.
Setup:- XR500, TP link N600 in bridge mode, Too many PC's game console to name here, though none of these are relevant. I have a VDSL2 connection to the house hence the TPlink. All has been well ...
Mrbchambers
Feb 24, 2020Guide
The XR500 is using PPPoE to connect to BT via a tp-link n600 in bridge mode. This was the only way I could connect without double Nat issues, and originally, there were no spurious log messages.
Is there a better way?
Netduma-Fraser
Feb 25, 2020NetDuma Partner
Remove the PPPoE details from the XR and disable the bridge mode on the N600. Have the N600 handle PPPoE instead then turn of its WiFi and put the XR500 WAN IP (found in System Information) into the DMZ of the N600. That will resolve the double NAT issue. Then see if the issues you've been seeing have been resolved back on the XR. I'd give it a reboot after setting this all up just to be sure it applies properly.
